cpu: i9 13900kf
ram: 2x32 gskill ddr5 6400 xmp1
vga: gbyte 4090 wc
mb: gbyte gaming x z790
os: windows11latest
cooling: water cooled
bios: latest
So, my PC started experiencing BSODs and I couldn’t troubleshoot the issue. Nothing made sense at first, and after exploring many theories, I eventually discovered that the P-cores of my CPU were causing the problem. I disabled them through the BIOS, and now my system is stable again.
I suspect that Intel’s microcode bug finally caught up with me and damaged some of the P-cores. For context: I always keep my BIOS updated, my CPU is water-cooled, and I’ve never overclocked it. Some might say it’s my fault, but I strongly believe this is an issue on Intel’s side—there was absolutely no reason for the P-cores to fail under these conditions.
I have been, and hopefully will continue to be, an Intel customer. However, this issue is serious and could be a dealbreaker for me. If CPUs are breaking down like this, it’s unacceptable. I really hope there is some kind of warranty coverage, because this is clearly a defective product and should be replaced.
Someone from Intel, please contact me. Otherwise, I won’t be purchasing Intel products in the future.
Hello Jigas,
1. When did you purchase the unit?
2. Was it working fine before?
3. Did you change any settings before the issue started?
4. What is the complete model of the motherboard?
5. Did you update the BIOS to the latest version and then loaded the default settings? If yes, how is the system after that?
By the way, if you need to claim Warranty for this product. You may need to contact your local warranty team:
Michael L.
July 2023 , just before 14gen release
Yes , working fine everyday since then. Problems start this year with some bsod now and then , until total crash this easter.
If you mean bios settings , no. Bios update on Oct2024 to F11
Gigabyte Z790 GAMING X (rev. 1.0)
https://www.gigabyte.com/Motherboard/Z790-GAMING-X-rev-10#kf
Yes, i am updating the bios on every update. Last update was Oct , 2024 on F11. Was working fine all the way to April 2025.
When the problems started , I updated the bios to F12 on April and still same. ( kinda hoped will work ).
The good news is that having the p-cores disabled my pc is stable and working.
So even with broken cpu i dont have to pay brand new cpu in order to be back online.
yea, no phone for Greece in Intels phone list.
Any other way to get support for us downhere , in the edge of the world?
Hi Jigas,
Thank you for sharing this useful information to us.
I do understand your frustration that you're experiencing on this.
I'll be sending you a private email about our discussion on this thread.
Kindly check your inbox from time to time.
Earl E.
