16871 Discussions
i9-14900KS stability problems
ndennis94
I assembled my PC with an i9-14900KS. I use the system for AI computing and it is running Debian 11 for an operating system. Whenever the computer is  doing something processor intensive, I hear the fans ramp up. Sometimes the operation will complete, but most of the time the system freezes where the only recovery is the power reset button. The freeze does not always happen at the same time in a specific operation. It happens in seemingly random operations, but always when the fans are ramped up.
I just tried swapping the memory, and the problem persists. I recently read about stability problems with these processors and am now assuming this is my issue. I am running new firmware on my Asus motherboard which has a setting called "Intel Baseline Profile". This setting has remained active and I am still having stability issues. What can I do about this?
Mike_Intel
Hello ndennis94,
For the BSOD issue, kindly open the community link where we posted our recommendations and follow the provided settings that you need to set inside the BIOS then tell us if there is an improvement.
https://community.intel.com/t5/Processors/Updated-Guidance-RE-Reports-of-13th-14th-Gen-Unlocked-Desktop/m-p/1594553
Michael L.
Mike_Intel
Hello ndennis94,
Michael L.
ndennis94
I applied the setting suggested in the link you provided. It appears to have fixed the problem.
GANNI
Hello
i got many crash with my processor I9 14900 KS
I try  everything, reset bios, last update change all setting
I GOT CRASH when i play.
Can you help me please
Mike_Intel
Hello ndennis94,
Thank you for the update and we are glad that the issue is now fixed. Since your system is now stable, I need to close this inquiry.
Michael L.
