16880 Discussions
intel cpu 2.53ghz to intel 3.0ghz
Dell DIMENSION 1100
celeron 2.53ghz
Can i put in a intel 3.0ghz Pentium 4?
RGiff
Honored Contributor I
There is alot to consider here. Does the CPU match the FSB , will it operate in the range of your RAM , is it the same socket , can it be used with the chipset you have now ???
Adolfo_S_Intel2
Please contact DELL* and ask them if the processor that you want to install on your DELL* system will work on it.
They are the ones that determine which processors will be compatible with their systems.
