16761 Discusiones
intel i9 14900K Overheating
H4WKEYE
Principiante
26.368 Vistas
Hi I have recently bought intel core i9 14900k and I am facing some games crashing (such as Shadow of The Tomb Raider, God of War, Rise of The Tomb Raider) while loading and the temp goes up to 80-100 with all the stock settings, I am using NZXT Kraken 360mm RGB as my AIO and I have checked the cooler is mounted properly as well as the thermal paste is spread across the processor correctly, now I am thinking that should I use a contact frame on my processor to reduce the temp or undervolting the processor?
Etiquetas (1)
0 kudos
9 Respuestas
Senkuchan
Colaborador Valioso II
26.324 Vistas
To address the overheating and crashing issue, you can try the steps mentioned in the following links:
https://www.intel.com/content/www/us/en/support/articles/000005791/processors/intel-core-processors.html
https://www.intel.com/content/www/us/en/support/articles/000028063/processors/intel-core-processors.html
Do you see any error message when the system crashes? There could be various reasons for this issue. Before we proceed to the next steps, please ensure that you have completed the recommended troubleshooting first.
H4WKEYE
Principiante
26.308 Vistas
Hello Senkuchan, Thanks for your reply
I would say that I have done all these troubleshooting and my bios is up to date and everything is checked for but still I am having overheating issues
Senkuchan
26.304 Vistas
I would like to verify if you have tested your processor on a different known motherboard to narrow down the issue. If the problem occurs on another motherboard with only the processor changed, it may suggest that the processor is defective. You can also run the ipdt test to check the processor's condition and send me the result.
You can find more information and instructions on these links:
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
https://www.intel.com/content/www/us/en/support/articles/000057810/processors.html
H4WKEYE
Principiante
25.725 Vistas
There is the results from IPDT test
KrissyG
Nuevo Colaborador II
26.290 Vistas
...i9 14900k, you know, when i bought the i7 13700k i was also surprised that water cooling is almost futile, and it can NOT keep it under 100°C at default settings = no power limit (it does max out at about 280Watts witnout OC)
NZXT Kraken 360mm is not good enough, i run double 420 rads with
Watercool Heatkiller IV Pro, and it still can't keep it cool, but for few minutes the CPU can run at 250W and not reach 100°C, but rather 90~95°C.
One 420 rad is bigger than your 360, on top of that, mine are 50mm thick.
What is the thickness on that Kraken 360? 35mm?
You said "I have checked the cooler is mounted properly" , and i can tell you, that you may think that you did that, but in reality, there is a like 10µm bigger gap on side, and that makes the temperatures go higher than expected.
Hint - use XTU to limit TDP to 120~150Watts, the 12,13 and 14 gen run at that TPD with optimal speed, anything more and the gains are so little, you won't even notice.
Yes, you won't be able to use it at 'full power' , but the question is, was that CPU ment to run at full power in the first place?
At room temp of 20°C and if i let it idle for few minutes, the idle temp will be about 28°C, i assume you get the same idle temp.
Now at default settings, which in my case should be 250W, the cooling for a short period of time is good enough to let the mother board run higher than 250W.
The thermal paste i use is Noctua NT-H2 , it is i would say bette than kryonaut, at least for me it is, bcoz i get higher power readings with it, as opposed to max 265Watts with kryonaut.
Yes, it takes few minutes to find out if the cooling block sits perfectly on the CPU.
It does not really matter how i spread the thermal paste, what matters most, is how well the cooling block sits on the CPU!
And if it is just the memory stress test for 1 minute, the temp will not reach 100°C or in other words, there will ne no thermal throttling at all:
The max TDP i can run continously is 230W, this will never trigger thermal throttling.
Run the memory stress tests yourself at various TDP limits, to find out, what is your water cooling capable of.
As far i know, i9 14900k easily does 350W without OC on default settings.......and you try to keep it cool with a single 360mm rad.
BTW, for the test you see on the screenshots, all fans on the 420 rads were running at bare minimum, bcoz there is barely any difference in fan speed....bcoz the colling block on the CPU releases water, which is NOT warmer than 50°C, it's the CPU that is horrible at transfering heat to the cooling block!
Get yourself at least one MO-RA3 420LT  radiator, if you plan on actually using almost the full power.
Andre_2203
Principiante
25.828 Vistas
Hey bro did you sort this out? Im having thr same trouble, i9 14900k kraken z 360 and my cpu reaches high temperature and crash games and even entire pc, Did you buy another liquid cooler or what? Looking forward for an answer
H4WKEYE
Principiante
25.723 Vistas
Hello bro, I have kind of solved the problem, I remounted my cooler with changing my thermal paste and also undervolted the cpu and limited the power wattage  so it can't draw more power than it needs and also I have installed a contact frame so that it contacts with the cpu cooler properly, my cooler remains the same. Now the cpu temp doesn't go beyond 65-70 but sometimes touches 75-78 degree celsius and comes down instantly while playing some heavy games like warzone, god of war and battlefield 2042 and under heavy load it barely touches 90 degree celsius. Its normal for a beast like i9 14900K to run at these temps.
Tehweeb
Principiante
25.646 Vistas
Did you undervolt through bios? What settings have you found to be the most stable? Having the same issues and so far all I've been able to do is reduce from 57x to 53x (p cores) with mostly stable performance but I have to adjust xtu every boot time since settings never save.
H4WKEYE
Principiante
25.611 Vistas
Yeah I undervolted through bios settings otherwise they won’t be saved every time you boot,
I just enabled power limit to 253w and undervolted at 0.075mv and remounted my cooler and changed thermal paste, these mostly did the trick
Responder
