17063 Discussions
intel kaby lake-S E3-1230 v6 and ddr4 2133 ECC Ram
PMart10
Hello
Is it possible to combine in the same machine the Intel KABY LAKE E3-1230 v6 3.5GHz with memory DDR4 2133 ECC?
In its spec's sheet:
https://ark.intel.com/products/97474/Intel-Xeon-Processor-E3-1230-v6-8M-Cache-3_50-GHz Intel® Xeon® Processor E3-1230 v6 (8M Cache, 3.50 GHz) Product Specifications
only appears: DDR4-2400, DDR3L-1866 in the memory types section (Memory specifications). (ECC is ok)
Although it doesn't appear there: is that memory compatible with this processor?
Thanks a lot
Hello P_J_,
According to the memory specification, ECC memory is supported in the memory types mention below.
As you can see DDR4-2133 ECC is not supported.
Amy C.
Hello P_J_,
Amy C.
PMart10
Thankyou very much Amy C.
My question arises since a local seller offers me that combination and he says that this memory is supported against my opinion.
Now I have arguments to decline its offer and choose other one.
Greetings from Spain
P_J_
P_J_, you're welcome. Maybe you can share the official memory specification with your local seller in order to get right one for your system.
Amy C.
