16790 Discussions
intel turbo boost is not working
Aalho
HP Omin 17 w201ne laptop
I7 7700HQ cpu @2.8 Ghz
UEFI BIOS from insyde
GTX 1070
I can't find ant option for intel turbo boost
I've tried to enable it from the BIOS and there's no option at all for OC
I've tried to instal turbo boost max 3.0 and the below message pop up
"ITBM driver not available - possibly BIOS configuration needed"
i've tried to install intell turbo monitor and the same message pop up
can you please help me since I'm having difficulty running some of the games with a GTX 1070!!
thanks
n_scott_pearson
Since BIOS implementation and the settings offered in BIOS Setup are the purview of the manufacturer, you will need to contact them (namely HP) regarding this question.
Frankly, I don't see Turbo Boost not being enabled as being the reason behind your gaming issues,
