17153 Discussions
mobo P5P43TD bsod issue with quad core 6600 & corsair ddr3
Hello everyone,
I have these days a weird issue with my new computer.
cpu Core 2 Quad 6600 2,4 Ghz
MOBO ASUS P5P43TD (s775, DDR3, P43)
RAM CORSAIR DDR3TW3X4G1333C9A PC3-10666 4GB Kit 9-9-9-24 240pin DIMM
WD HDD 640 GB
VGA ATI RADEON 4650 1GB ddr2
When I'm trying to install whatever 64bit OS I receive blue screens during
the installation process. The errors are such ntfs.sys or numbers like
0x00000024
I cannot find where is the problem.I updated the bios with the latest
update,tried with default settings,tried to change settings to bios the fsb
and the memory latency the voltage everything and have the same results the
blue screen.Also tried to change the HDD,power supply, tried with different
media,tried with different dvd rom the same result!
I have checked to change the VGA,make memory test with mmtest no errors.
I have unpluged all usb devices and internal pci cards again the same
PROBLEM!I have tried with different RAMs again the same issue.
Finally I have tried to another Mobo Asrock to install there the CPU if I
have a problematic CPU but install successfully vista 64bit.All cables inside
the desktop are changed with news ones
So the result is BSOD!!!
I do not know what else to try.I have changed everything
Obviously I think there is a compatibility issue between the Asus mobo with
Corsair RAM or with CPU.
Any suggestions will be preferable
Thanks in advance guys!
Have you tried installing a 32 bit os? it would be worth it to test the system.
Also are you trying to install form the same cd every time? have you tried another one?
