17160 Discussions
my computer turns of and on after instaling new cpu
Hi im Valomas and im having a little issue iv just got a new processor a INTEL BX80646I74790K Boxed Intel Core i7-4790K Processor (8M Cache, up to 4.40 GHz) FC-LGA12C - Devil's Canyon and I installed it and when i turned my computer on it just turned of and on until I turned the power of help pls
AlHill
Does the i7-4790k replace a i7-4790k?
Or, did you upgrade from a lower processor?
If you upgraded, do you know for certain that your motherboard supports the i7-4790k? Even if you had a Haswell processor (and same socket), some boards cannot run the Haswell-refresh processors, even with a BIOS update.
If the motherboard does support the processor, did you make certain your board is at the proper BIOS level?
If your board does support the i7-4790k, but you are at the wrong BIOS level, re-install the lower processor, update the BIOS, then re-install the i7-4790k.
Provide the motherboard manufacturer and model number, and the previous processor full model number.
Doc
no im replacing a i5 4670k let me try to find were the info on my mother board is
AlHill
The i5-4670k is a Haswell processor, the i7-4790k is a Haswell-refresh (Devils Canyon) processor.
http://ark.intel.com/compare/80807,75048 ARK | Compare Intel® Products
Now we really need to know if your motherboard supports the i7-4790k processor, and is at the proper bios level.
Doc
ok the motherboards manufacturer is gigabyte technology co. ltd
model Z87-HD3
chipset intel haswell
southbridge intel z87
lpcio lte it8728
BIOS brand american megatrends inc.
Version F4
Date 05/16/2013
i hope this helps
o and the processor im trying to install is a
AlHill
The gigabyte site says you need to be at F7 to use the i7-4790K.
http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=4489 GIGABYTE TECHNOLOGY Socket 1150 - Intel Z87 - GA-Z87-HD3 (rev. 1.x)
Re-install the i5-4670K (which really needs to be at F6, and you are running F4), update the bios to F7, then install the i7-4790K.
Doc
hello ?
Version F4
srry the replys are delayed
AlHill
No problem. I will be leaving in a few minutes. You are on your own now.
Doc
before you go can you link me to were i need to update to f7 ?
thank you so much have a good one m8
AlHill
I will be gone for 8 hours or so. Whatever the case, report back with the results.
Doc
Hello:
Thank you very much to Al Hill for the comments posted above.
To Valomas:
I just wanted to conform the previous information as correct, by doing a BIOS update to the latest version you should be able to use the processor with that board.
Alberto
