16887 Discussions
my i7 is working of 100% only 1st core,what to do?
yyas
i dont know after what is happened,laptop work as pentium 4,cpu is i7 3630qm
AChel2
Its normally gives high priority to first core, try to use a high CPU usage prg(game/converter etc...) and put your laptop on high performance(from the battery icon).
Or control panel>admin tool>system configuration>Boot>advanced options> number of processor.
yyas
System Idle is always 99 percent, laptop slows scary, uploaded only the first core, sometimes it is overloaded. I do not remember what happened after, but first he has worked very well and quickly, now, like a turtle, even my old P4 is faster.
Hans_B_Intel
Intel has a tool that would let you test the processor.
Run the Tool and attach the results:
Intel® Processor Diagnostic Tool
http://www.intel.com/support/processors/sb/CS-031726.htm http://www.intel.com/support/processors/sb/CS-031726.htm
yyas
.TestResults_Full
--- IPDT - rev 2.8.0.0 ---
--- Start Time: 12/31/2014 21:57:58---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 36 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i7-3630QM 2.40GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 2.40
Detected CPU Frequency is --> 2.4
CPU Frequency Test Passed!!!
--- FSB NOT Supported on this Processor ---
--- Running Base Clock test ---
Detected Base Clock --> 100
Base Clock test Pass ---
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 288
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 3.3229e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 4 x 32
- Detected L1 Inst Cache Size --> 4 x 32
- Detected L2 Cache Size --> 1024
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
MMX SSE Testing Passed !!
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> No ---> No Test Required
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- Not Tested
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
AVX Compare Test - Not Tested
AVX support detected on your Processor
AVX not supported by your Operating System
Minimum Operating System requirements are
Windows 7 SP1, Windows Server 2008 R2 SP1
Linux kernel version 2.6.30
AES PCLMULQDQ Testing Passed !!
--- Reading Memory Size ---
Detected Memory Size is --> 3.13GB
--- Integrated Memory Controller Stress Test ---
--- Integrated Memory Controller Stress Test Pass!!! ---
Integrated Memory Controller Test Pass!!!
Chipset : Mobile Intel(R) HM76 Express Chipset
Chipset Stepping : C1
1 device connected to PCI Express Port 0
1 : NVIDIA GeForce GT 635M
1 device connected to PCI Express Port 1
1 : Realtek PCIe GBE Family Controller
1 device connected to PCI Express Port 2
1 : Qualcomm Atheros AR9485WB-EG Wireless Network Adapter
2 device connected to SATA Controller 1
1 : ST750LM022 HN-M750MBB
2 : Hitachi HTS547575A9E384
No device connected to SATA Controller2
4USB devices detected
1 : Atheros AR3012 Bluetooth 3.0 + HS
2 : ��������� USB ����������
3 : Realtek USB 2.0 Card Reader
4 : USB HID-����������� ����������
2 device connected to Intel High Definition Audio Controller
1 : Realtek High Definition Audio
2 : ����� Intel(R) ��� ��������
--- Platform Controller Hub Test Completed!!! ---
--- Querying for Intel(R) Integrated Graphics Device (IGD) ---
..Detected 8086 as Vendor ID on Device 2 on Intel(R) processor..
..Intel(R) Integrated Graphics Device Presence Detection Passed..
..2D Graphics Visual Display Passed..
..Graphics Visual Display Passed..
..Rotating Display Passed..
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
Temperature = 0 degrees C below maximum.
--- Test End Time: 12/31/2014 22:02:00---
System Information
Processor Name: Процессор Intel Pentium III Xeon
Processor Information: x86 Family 6 Model 58 Stepping 9
Number of Physical Cores: 4
Number of Logical Cores: 8
Installed System Memory: 4 GB
Operating System: Microsoft Windows XP Professional
Graphics Information: NVIDIA GeForce GT 635M
System Product: K75VJ
System BIOS: 221
--- IPDT - rev 2.8....
Hans_B_Intel
According to the report, you have a healthy processor.
If your system is running 100% in idle, you may want to run a complete system check and look for malware or viruses.
yyas
i'll try and report after...thnx
yyas
something is happened......
--- IPDT - rev 1.32.0.0 ---
--- Start Time: 06/14/2015 11:06:22---
Temperature = 50 degrees C below maximum.
Detected CPU Frequency is --> 2.39375
Detected Base Clock --> 99
!!! --- Base Clock test Fail --- !!!
--- Test End Time: 06/14/2015 11:06:35---
core speed became 1197,14 !!!!!
why ??????????
what is a reason,what to do?
Hans_B_Intel
This means that the test did not detect the correct base clock frequency. The detected was 99 and typically should be set at 100. This may be something that can be configured through the BIOS, but you would need to contact the manufacturer of the computer for instructions on how to check this.
