i have 10700k with asus z490 i motherboard
i updated my bios and boot up normally and everything was fine
but after i use MEUpdateTool_14.1.75.2420 _T
and system stuck on boot loop
i checked all the component everything works fine it just won't boot
i spend last 3 hour trying to boot up my system
only way i can boot up my system is CMOS reset then to the bios then boot option and click on a drive only then it boot up
but if restart my computer it go back to boot loop so i have to repeat that steps again
please look in to this matter thankyou
Hello toryappa,
It seems that the issue you're experiencing occurred after using the MEUpdateTool. This tool is designed to update the Intel Management Engine (ME) firmware on ASUS motherboards. Given that your system functions normally after resetting the CMOS battery and manually selecting the boot drive in the BIOS, the problem might be related to the ME firmware update.
Here are some steps you can take to address this issue:
- Consider re-flashing the ME firmware using a different version or tool, ensuring compatibility with your motherboard and processor.
- After resetting the CMOS, double-check that all BIOS settings are correctly configured, especially those related to the boot order and ME firmware.
- Ensure your BIOS is updated to the latest version, as this might resolve compatibility issues with the ME firmware.
- Since the issue persists after using the MEUpdateTool, it would be beneficial to reach out to ASUS support for further assistance. They may have additional insights or solutions specific to your motherboard model.
Additionally, I wanted share this information on about the guide for MEupdate tool: https://www.asus.com/support/faq/1047868/
Dhanniel M.
Hello toryappa,
Dhanniel M.
Hello toryappa,
I wanted to follow up to see if you had a chance to review my previous recommendation regarding the issue you encountered with the MEupdate tool. If you have any further questions or need additional assistance, please feel free to reach out.
Dhanniel M.
hi thankyou for taking your time to looking in to this
Hello toryappa,
You can still reach out to Asus for technical support even if your motherboard is out of warranty. For issues related to the MEUpdate tool, such as deleting and reinstalling it, it's advisable to contact Asus directly. They have the expertise to assist you with these technicalities.
Regarding the options you mentioned, waiting for a new MEUpdate tool release might not be ideal since there's no set timeline for its availability. Therefore, contacting Asus for further assistance would be the best course of action.
Dhanniel M.
i have reached out to asus
they're the one who told me im out of warranty they said send in the motherboard they will check it for $35
whatever cost to fix it will be extra so im out of compurter for weeks and then not sure how much will it cost
or even is possable
asus costomer was a joke
but i found a solution (not a perfect one)
i found someone in the internet with same issue who also have asus itx motherboard
he rollback bios like way back to before windows 11 version
without tpm2 only then computer turn on and off it self normally
because it won't support tpm2 LOL vengard will crash so i can't play riot based games
this have to do for now and just upgrade soon i guess thanks for your help
Hello toryappa,
I'm glad to hear that you found a solution. With that in mind, may I proceed to close this inquiry? If you have any other questions or need further assistance, please feel free to reach out.
Dhanniel M.
Hello toryappa,
Since I haven't received a response from you, I will proceed to close this inquiry. If you require further assistance, please feel free to submit a new question, as this thread will no longer be monitored. Thank you for your understanding.
Dhanniel M.
