16840 Discussions
parameters to XTU
kaa
Is it possible to run XTU with a parameters, example:
net start xtu3service profile=profile1
or similar?
Jean_Intel
Hello kaa,
Thank you for posting on the Intel️® communities. I understand you are looking for more information about the use of the Intel XTU.
  • Could you confirm which is your CPU model?
  • Can you provide me with a more detailed description of what exactly you are trying to do?
Jean O.
kaa
Hello Jean O. ,
Sorry, my question has nothing to do with processor type.
My opinion is that my question is absolutelely clear :
Is it possible to start XTU with values saved in XTU profile or similar?
Best Regards
Peter Novak
Jean_Intel
Hello kaa,
Thanks for your response.
To answer your questions, you can save the profile in Intel® XTU so that you have a known working configuration. This can be useful when replicating different tests and for saving successful tests.
In order to save a profile, head to the “Profiles” tab and click “Save”. You will be able to name your profiles and organize them.
To load a saved profile, visit the “Profiles” tab and select the one you’d like to load. Click the “Show Values” button to pre-load the settings (changed values appear in yellow), and then click “Apply” to use those settings.
If this information doesn't answer your question, I would like to request you to provide more details of what you are looking for. It would be important to have the CPU model to confirm if the processor is supported by the tool.
Jean O.
Jean_Intel
Hello kaa,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello kaa,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
