- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
ı have excalibur g770 laptop with 11th Gen Intel(R) Core(TM) i7-11600H @ 2.90GHz and 3050,
when ı play games my processer Ghz down to 1Ghz, ı am sure it is not about temperature because ı clean fans once a month. but ı downloaded core temp and there is 2 core above 90 degree but others like 75-80. I tired everythink like booting my win11, bios update, driver update. I realy dont know why this is happening.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello NsaMoon,
Thank you for raising your concern through the Intel Community.
To properly investigate the issue and better understand the situation, I would like to ask a few questions:
- Is your exact laptop model Excalibur G770 Gaming Laptop - Gaming PC | Casper?
- Where did you download the drivers?
- Could you provide more details about the issue where the CPU frequency drops to 1 GHz while playing games?
- Have you tried reaching out to the OEM (Original Equipment Manufacturer) regarding this concern?
To further assist you, I kindly ask you to download and run the Intel® System Support Utility (SSU) so we can review your complete system specifications.
Intel® System Support Utility for Windows*
Once the download is complete, please follow these steps:
- Launch SSU.exe.
- Under Scan, check the box Everything.
- Click Scan.
- After the scan is finished, click Next.
- Click Save and send the generated report.
Once I receive the report and your answers to the questions above, I will proceed with further investigation.
Thank you, and I look forward to your response.
John M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi JohnM_Intel,
1- Excalibur gaming laptop
2- I download driver on https://www.casper.com.tr then ı update processer and graphic card with "intel Driver and support assistant, Nvidia app"
3- normally processer speed is between 3Ghz and 3,70Ghz. But when ı start a game and playing the about 2 minute processer occupancy/usage goes to 90-100% however graphic card like 20-30%.
4- No, ı didn't contact with Casper, because ı realy don't like their customer service.
The requested file is attached.
Thank you for your help,
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello NsaMoon,
Thank you for your response and for the clarification. To better isolate the issue, kindly provide the information below:
- What activity are you performing when the frequency drops?
- Was the system working properly before this issue started?
- When did you first notice the frequency drop?
Additionally, please try the following troubleshooting steps:
- Test your system using the Intel® Processor Diagnostic Tool and provide the results.
- Test your system using the generic graphics driver version 32.0.101.7084.
Once you have completed the steps above, please provide an update so I can assist you further.
Thank you for your cooperation.
John M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello JhonM_Intel,
1- Frequency drop when ı start playing game.
2&3-Actually it is an old problem like about 2-3 year. when i realize there is a problem i sent my laptop to casper technical support team, they said they didn't find any problem and i ignore the problem since the technical support team said there was no problem, I continued to use my computer even though it was malfunctioning until 05.03.2026
Then my friend said to me, we have same laptop but why you cant even play game that ı can play with my pc.
After this conversation, I update my bios and all my driver after this process the problem is fixed and ı can play every game without any drop until 10.03.2026. That date windows install "Intel Corporation - Extension - 27.20.100.9565 " . After update ı tried to play game and problem starts again.
ı update my graphic driver to 32.0.101.7084. but frequency still drop and my graphic card's(3050) usage still between 60%-5%
Thank you for helping.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello NsaMoon,
Thank you for the detailed information and for explaining the timeline of the issue. I appreciate the effort you have taken to investigate your system’s behavior.
Based on your description, it appears that the issue initially returned after the Windows update installed Intel Corporation – Extension – 27.20.100.9565, and then resurfaced again later. To further isolate this issue, kindly follow the steps below:
- Perform a clean installation of the graphics drivers using Display Driver Uninstaller (DDU) to completely remove the current graphics drivers, then reinstall the latest graphics drivers.
- Check your power settings and ensure the system is set to High | Best Performance when gaming.
While you complete these steps, I will also check this internally so I can provide you with the next steps in our following interaction.
I’ll wait for your update once the steps have been performed.
John M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello NsaMoon,
Thank you for your patience.
To help us further investigate the issue, I would like to gather a bit more information:
- Did you make any system changes or update any drivers before the issue started?
- Have you tried updating the BIOS on your system?
- When the processor frequency drops, do you notice any performance issues or system lag?
Additionally, you may find the following articles helpful for reference:
- Why the Processor Frequency is Operating Below the Base Frequency for...
- My Processor Constantly Runs at Low Frequency, Causes System Lag
Please let me know your findings so we can continue working on this together.
John M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello NsaMoon,
I just wanted to follow up and see if you’ve had time to go through the information I posted. Please feel free to update me at your convenience so we can determine the next best steps.
John M.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello NsaMoon,
As I have not received a response from you, I will be closing this inquiry for now. If you require further assistance, please feel free to submit a new question, as this thread will no longer be monitored.
Additionally, I recommend reaching out to Casper, the OEM, as they have more detailed insights into your system configuration and may be able to provide more specialized support.
John M.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
