16937 Discussions
problem with Intel I5-3470 VT support?
杰谢
I already enabled Intel Vituallization Tech In BIOS Advanced Settings, but on my VMware workstation 10 Guest Machine- Ubuntu, when I modprobe kvm-intel, "Operation not supported" occured, dmesg shows "Hardware not support", which is same as redhat 6.4.
And I have checked the vm settings of CPU. I tried on another host with Intel core i5-3230M CPU, it's the same.
My host is Win7 64-bit Operation System.
Can Someone provide some advice ?
Silvia_L_Intel1
JackXie, could you please provide me the model number of your motherboard or the system you are using? I would like to replicate this issue, but I need all the information you could provide me.
A detail description of the behavior will be helpful.
杰谢
motherboard : Intel H65
HOST OS - Win7 64bit Ultimate
CPU - Intel Core(TM) i5-3470 CPU @ 3.20GHz
RAM - 8GB
TOOL - VMware workstation10
Guest OS - Ubuntu10.04 desktop 64bit,
Now I want to run another virtual machine with kvm on Ubuntu10.04, So I need to modprobe kvm-intel on Ubuntu10.04,
but as I said, "Operation not supported" occured, dmesg shows "Hardware not support".
I already enabled Intel Vituallization Tech In BIOS Advanced Settings.
Silvia_L_Intel1
Thanks for the information Jackie. I'm going to set up a lab in order to try to replicate this behavior.
I'll keep you posted
Silvia_L_Intel1
JackXie, I would like to inform you that we are still working on this issue.
Once we have an update I will let you know.
We found this information on VMware communities https://communities.vmware.com/message/2278512 Enable VT-x switch for HOST | VMware Communities
