17517 Discussions
processor i5 3230m
pcolo2
hi, ive some trouble with my laptop dell e6430
processor is maybe underclocked
thanks
Allan_J_Intel1
Try running the Intel(R) Processor Identification Utility, this will provide reported and expected processor speed:
http://www.intel.com/support/processors/tools/piu/sb/CS-014921.htm Intel® Processor Identification Utility — Intel® Processor Identification Utility Download for Windows*
Also, see if the processor has some problem by running processor diagnostic tool: http://www.intel.com/support/processors/sb/CS-031726.htm Processors — What is the Intel® Processor Diagnostic Tool?
Allan.
pcolo2
ive turned off speedstep in the bios, now i have the correct frequency but the processor is at the max frequency all the time. is there a way to regulate the frequency without speedstep?
Allan_J_Intel1
You have a mobile computer, speedstep should be enabled to lower processor frequency and save power on your system. If you are looking for other ways to modify the processor frequency, you need to check your computer BIOS for different settings that may help on this matter.
Allan.
