processor
my i7-4790K already test 3 motherboard which the result is the same as shown Pcie X16 slot 1 was unable to detect external graphic card
AlHill
Try a different graphics card.
Doc
Tested with Asus R9380 strix 4gb and msi gtx 970 gaming and also nvidia GT320 gpu not working too. Any help will be appreciate. Thanks
AJana1
Valued Contributor I
Hello alex2381,
http://ark.intel.com/products/80807 Intel® Core™ i7-4790K Processor (8M Cache, up to 4.40 GHz) Specifications
https://www.asus.com/Graphics-Cards/STRIXR9380DC2OC4GD5GAMING/specifications/ STRIX-R9380-DC2OC-4GD5-GAMING | Graphics Cards | ASUS Global
From the above two links, the support and compatibilities information could be confirmed. First of all, for one thing is the parameters for UEFI/CMOS be configured correctly? Or in other words, has the PCI Express has been enabled, and the default GPU was set to it rather than the integrated GPU?
Aaron Janagewen
Hello alex2381:
Let me apologize for any inconvenience.
I just sent you a private message, please verify your inbox.
Alberto
hi Janagewen
i tested with default setting to auto, by right auto in gpu is once detected the gpu in the slot. it will sent signal to it.
AJana1
What about power supply, I mean have you connected all the connectors to the motherboard and display card? If you master in those fields, I think you'd better contact with Intel support for replacement of processors. Anyway, I just wish you good luck!
