16840 Discussions
"A connected hardware error has occurred: Reported by component: Processor core. Error Source: Corrected Machine Check. Error Type: Internal Parity error. Processor APIC ID: 2"
GInne1
I am getting this windows system log message on a PC I have just built with the following spec
Processor:Core i5-4670 S1150 3.4GHz 6MB Cache Haswell Quad Core.
Mobo:AzrockZ97M Anniversary/M/ASRK
Power supply:Corsair CX500M Modular.
Memory:Corsair CMV4GX3M2A1333C9 DDR3 2x2MB
This message has appeared right from the word go and all cores get mentioned at different times.
Initially I used the hard drive from my old PC with Windows 8.1 but I read that a clean install might solve the problem so I Formatted the drive and reinstalled the OS but that has not made any difference.
I have checked core temperatures and they are well below max. I am not experiencing any other problems.
Is this a processor fault or something else, any advice would be appreciated
Allan_J_Intel1
Thanks for joining the Processor community.
You may need to run processor diagnostic tool and detect if the processor is defective or not.
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=19792&lang=eng IPDT 64bit
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=19791&lang=eng IPDT 32 bit
Try updating motherboard BIOS as well: http://www.asrock.com/support/download.asp?Keyword=Z97M&Type=MB&Socket= Download Files form ASRock Inc.
Allan.
GInne1
Hi Allan,
I have checked the BIOS, it is up to date. I have run the diagnostic tool several times including burn in mode and the result is always a Pass. Does a Pass mean definitively that the processor is OK ?.
I have also tried looking at windows logs to find other errors that happened at the same time, but that is quite a job and I did not have any success.
I have included the details view of the error log below, there seems to be a lot of information there but it means little to me but perhaps this is out of your remit.
DETAILS VIEW
- <</span>Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event http://schemas.microsoft.com/win/2004/08/events/event">
- <</span>System>
<</span>Provider Name="Microsoft-Windows-WHEA-Logger" Guid="{C26C4F3C-3F66-4E99-8F8A-39405CFED220}" />
<</span>EventID>19</</span>EventID>
<</span>Version>0</</span>Version>
<</span>Level>3</</span>Level>
<</span>Task>0</</span>Task>
<</span>Opcode>0</</span>Opcode>
<</span>Keywords>0x8000000000000000</</span>Keywords>
<</span>TimeCreated SystemTime="2014-11-22T20:32:55.066322600Z" />
<</span>EventRecordID>63181</</span>EventRecordID>
<</span>Correlation ActivityID="{E357EF4D-62AA-4FC9-9831-5EF1FE30413B}" />
<p style="margin-bo...
Allan_J_Intel1
The processor diagnostic tool provides accurate information.
Have you tried testing different processor?
If you do not have spare processors. You may need to call Intel support at:
Online warranty:
https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx Service Request Email
Chat support:
http://www.intel.com/p/en_US/support/contactsupport Contact Support
Allan.
