16761 Discussions
"Download Linux version of IPDT" is very bad
SLegg
This link:
https://downloadcenter.intel.com/download/19791 https://downloadcenter.intel.com/download/19791
Ultimately leads you to this ISO:
http://www.tcsscreening.com/files/users/IPDT_LiveUSB/LiveUSB/Fedora20/f20_64b-xfce-2.20.0.0.L.MP.iso http://www.tcsscreening.com/files/users/IPDT_LiveUSB/LiveUSB/Fedora20/f20_64b-xfce-2.20.0.0.L.MP.iso
That uses this Kickstart file:
http://paste.fedoraproject.org/271239/14431285/ # 271239 • Fedora Project Pastebin
That has this line:
clearpart --all --initlabel --drives=sda
My question is... Why? Why is there not a disclaimer that says "Hey, clicking on the "Install" button will delete all information on your hard drive without prompting you!" A better question is, why is this line in there at all? Why not prompt the user to select partitioning?
Also, Fedora 20 is EOL.
Esteban_V_Intel
The Intel diagnostic tool does not have a line that will delete your data. Probably you were trying to create a bootable drive but you select the wrong drive. Bear in mind that when you create bootable flash drive it will deleted the partition first
SLegg
  • "The Intel diagnostic tool does not have a line that will delete your data."
I never said this. Notice I mention "Kickstart File" which has to do with the OS installation process.
  • "Bear in mind that when you create bootable flash drive it will deleted the partition first"
That's good info. But, it brings me back to my previous point:
"A better question is, why is this line in there at all? Why not prompt the user to select partitioning?"
Why is there no information about bootable drives that says "It will erase your data without warning."
Anonymous
Not applicable
Hi StrikerTTD,
Thank you for your update, we will take them in consideration on future releases.
Mike C
