16761 Discussions
recommended cooling for this processor Core i9-14900K 14th Gen 24-Core 32-Thread - 4.4GHz
Rinconjoe
Recommended cooling for this processor. I was wondering if there is a minimum small AO cooler or air cooler. small case Unfortunately I looked for info from Intel but didn't find any answers
Intel - Core i9-14900K 14th Gen 24-Core 32-Thread - 4.4GHz (6.0GHz Turbo) Socket LGA 1700 Unlocked Desktop Processor - Multi
Model: BX8071514900K
TheExpertGuy
hello the Intel Core i9-14900K (14th Gen, 24-Core, 32-Thread), this is a high-performance CPU with a significant power demand and heat generation, especially when boosting to 6.0 GHz under load. Given its unlocked nature, the processor is designed for overclocking, which can further increase heat output. For optimal performance and cooling, it’s important to choose a cooler that can handle the high thermal output effectively. The cooling requirements for you CPU TDP (Thermal Design Power). The i9-14900K has a base TDP of around 125W, but it can easily exceed 250W (or more) when overclocked or under heavy load. Thermal headroom: As this processor is capable of reaching up to 6.0 GHz, ensuring efficient cooling is crucial to prevent thermal throttling or damage to components. Large air coolers are generally recommended for high-performance CPUs like the i9-14900K due to their ability to handle high heat dissipation. However, if you have a small case, you will need to focus on air coolers that fit the available space. I recommend, Noctua NH-D15, Dark Rock Pro 4, Cooler Master Hyper 212 Black Edition, and Scythe Fuma 2. BUT If you're constrained by a small case, make sure to double-check the cooler's dimensions and the available space inside your case. For an i9-14900K, air coolers below $50-$100 might struggle with sustained high loads.
Ultimately, you should select a cooler that fits your case, provides adequate cooling for sustained workloads (such as gaming or rendering), and is capable of managing the i9-14900K's thermal output, especially if you plan on overclocking.
Rusty333
I'm about to switch from my i5 8600k to i9 14900kf kit with ROG STRIX Z790 Gaming-H mobo, 32gb ddr5 6000mhz kit. I currently plan to keep my cooler, which is Dark rock pro 4 and CM Storm Trooper case which has 5 120mm fans and 1 200mm on top. Will this be enough to keep the cpu cool enough?
AlHill
You will not be successful.  The i5-8600K uses socket 1151 and the i9-14900kf uses socket 1700.
Not only will your cooler not fit (unless you still have the adapter), you will also need a new motherboard (which I assume is th z790).  And, you may want to consider a power supply upgrade.
You need to do a lot more research before you attempt this venture.
[IDSA needs to be abandoned, uninstalled and forgotten]
Rusty333
I mentioned that in the kit I'm getting ROG STRIX Z790 Gaming-H mobo with 2x16gb ddr5 6000mhz ram
AlHill
Then read this:
https://pcbuildcomparison.com/best-cpu-cooler-for-i9-14900k/
Rusty333
Yes I read that already, but I'm questioning If the cpu will sustain normal temps with Dark rock pro 4 and Cooler master Storm trooper case. The case is XL-ATX
AlHill
What is "normal"?  If you have read the forum on the i9-14900K (f), you will see that nothing is normal.  Sorry, but you will not get a straight, definitive answer here.  No one will say with certainty the answer you want, and certainly not Intel.
Rusty333
"normal" reffering as temps not reaching higher than 80 celsius. I've read and watched a lot of videos for i9 14th gen and by that I can safely say most of guys saying this cpu is running hot, are the ones who put the build into a micro-atx cases.
