16961 Discussions
skylake i7 6600u latency test
GChou1
My customer requirement i7 6600u need meet latency test
Could you tell me need setting some item. (BIOS/OS...)
Attached file is latency test result
And customer notice to me , it's need intel fine tune.
Could you help for this question ?
Thanks advance
Hello 莊明運,
I would like to get more details regarding your inquiry, please elaborate on what you are trying find from our end.
Amy.
GChou1
Hi Amy
Our test condition is i7 6600u + PCIe card (customer specify) , OS is WES7 test CPU to PCIe real time.
test result format you can see attached file (previous one)
We have tried set up BIOS , disable P state/C state/Hyper-threding ... , but test result is not good
test result as below
ISR start : 32us ; IST start : 43 us ; PCIe read/write : 21us , test time 100 minutes.
Our customer judgment condition , ISR start < 15us ; IST start < 30us ; PCIe read/write < 3us , test time over 70 hrs.
Did you have any recommend ?
Thanks advance
/thread/114276 莊明運, thank you for the clarification.
Please let me double check this matter.
Amy.
/thread/114276 莊明運, looked into our databases for information that could help in this case; however, I was unable to find any piece of information related to this matter. I can share with you that our processors are configured with the correct settings and default settings. So at this stage, my recommendation is to get more feedback from other forums, sites like; http://www.tomshardware.com/ Tom's Hardware: For The Hardcore PC Enthusiast and https://www.overclockers.co.uk/ PC Systems & Components | Overclockers UK .
Amy C.
GChou1
Hi Amy
thanks for your feedback , but I still did not find the relevant information
if is RT (Real Time performance) setting about CPU to PCIe , did you have any information to us reference ?
Thanks advance.
/thread/114276 莊明運, l will have to check if that information is available from our end.
I will keep you posted.
Amy C.
/thread/114276 莊明運, I have sent a private message, please check your inbox.
Amy C.
GChou1
I got the message , and i will sent E-mail to mailto:ctp.determinations@intel.com ctp.determinations@intel.com
Thanks a lot.
Sure, you're welcome.
Amy C.
GChou1
Hi Amy
From CTP determinations feedback as below.
Unfortunately this type of request is beyond the scope of the CTP Determinations inbox.
Thank you
I am sorry to hear.
Unfortunately, from our end this type of information cannot be found from our end. My recommendation, like mentioned before is to get more feedback from other forums, sites like; http://www.tomshardware.com/ Tom's Hardware: For The Hardcore PC Enthusiast and https://www.overclockers.co.uk/ PC Systems & Components | Overclockers UK .
Amy C.
