16946 Discussions
unable to install vidual graphics in windows 8.1 pro
madhi
am using intel i5 7th gen processor . i faced some problems in windows 10 and now i am using windows 8.1 pro . before installing windows 8.1 the brightness controller worked well but after installing 8.1 i cant adjust the brightness i tried to implement the drivers given on the web but no thing solved the issue . its a 32 bit windows 8.1 .. i searched for a long time and tried several drivers on the web and also went through the threads in the community but none of it solved my problem .. i want some help. whenever i tried to install the driver i said that the minimum requirement is not fulfilled .. what can be done for this issue
AlHill
Sorry, but only windows 10 is supported on 7th gen (and later) processors. There are no drivers for anything less than Windows 10.
You must go to Windows 10 if you want driver support.
Doc
