17151 Discussions
vPro/AMT support in 14900K
jordipalet
I'm using a mother board that supports AMT/vPro. It worked with i12900K, so I can run remote management.
Now is not working with 14900K.
Is not longer available this feature?
It doesn't make sense to lose functionality ...
RamyerM_Intel
Hi jordipalet,
Thank you for reaching out to our community.
I can confirm that the 14900K no longer have this functionality as shown in this filtered list that I have created for the CPU that supports vPro Platform Eligibility : https://ark.intel.com/content/www/us/en/ark/search/featurefilter.html?productType=873&0_VProTechnology=True&1_Filter-Family=122139&2_MarketSegment=Desktop
However, I understand that you want an explanation why this functionality is no longer supported seeing that you have been using this feature in your previous CPU. To provide a detailed description of this information, I will coordinate this with our team internally and keep you posted.
Ramyer M.
jordipalet
Yes please. I need to understand why this has been disabled and also if I really have any advantages then using the 14900K, instead of for example going to the 13900K or 13900KS.
What are the newer features in the 14900K? Less power and heat, just a 2% of performance improvement, what else? I tried to compare them using ARK and is not useful ... I need to decide if return the 14900K and move to a 13900K or KS or even stay with the 12900K ...
There should be a more clear indication of the good and bad of each one when comparing them!
NormanS_Intel
Hello jordipalet,
Thank you for your response. We will update you as soon as we have any new information on this case and we will share it on this thread.
Norman S.
RamyerM_Intel
Hello jordipalet,
Thank you for patiently waiting. Upon checking with my team, I want to let you know that our 14th Gen processors will have vPro support and the vPro webpage and related documents like ark.intel.com will be updated soon. We sincerely apologize for any inconvenience this has caused you.
Ramyer M.
