16771 토론
whill these intel processors be able to run Crysis 2
직원
2,593 조회수
Crysis 2 system requirements:
Core 2 Duo E6750 2.66GHz
GeForce GT 140
Radeon HD 6570
3 GB RAM
http://www.game-debate.com/games/index.p...Crysis%202 http://www.game-debate.com/games/index.p...Crysis%202
Dell XPS Laptop:
2nd generation Intel® Core™ i5-2430M processor 2.40 GHz with {dual core}
2nd generation Intel® Core™ i7-2670QM processor 2.20 GHz {dual core}
Both have 4 GB RAM
and
1GB NVIDIA® GeForce® GT 525M graphics with Optimus
Will both of them will be able to run it easily ? Which of the the will be better ?
Will they use Turbo Boost to run it or not ?
0 포인트
2 응답
Adolfo_S_Intel2
1,338 조회수
Please check the following website to compare the features of both processors:
http://ark.intel.com/compare/53450,53469 http://ark.intel.com/compare/53450,53469
Since the game developer is the one that determines the hardware requirements for their games, and also they are the ones that perform the tests, they are the ones that can properly answer your question regarding if any of those processors will support that game or not.
0 포인트
직원
1,338 조회수
You're comparing a desktop system (Core 2 Duo E6750, etc) to laptop PCs, which is not easy. (BTW, a GT 140 does not exist.)
It's not the CPU that will determine if you can run Crysis, but the GPU, as they do most of the work with games.
The 525M graphics chip is a lower end model, but then so is a GT240 and HD6570. The 525M might only barely play Crysis 2, well known as one of the most demanding games, and then only on the lowest settings. "Optimus" means the GPU will turn off when not gaming, and use even lower quality graphics, no help at all for games.
Look for a better GPU chip, check NVIDIA's website to compare their mobile graphics chips:
http://www.geforce.com/Hardware/NotebookGPUs/geforce-gt-525m/performance http://www.geforce.com/Hardware/NotebookGPUs/geforce-gt-525m/performance
0 포인트
응답
