x5550 vs e5630
Hello
We are trying to get machine for SQL server. and the two options we have in terms of processor are either x5550 or E5630. Could you please let me know which one is better for SQL Server?
Our possible server configuration will be
2x x5550 or e5630
32 GB RAM
Thank You
Adolfo_S_Intel2
I would suggest checking the following link to compare the processor features:
http://ark.intel.com/Compare.aspx?ids=47924,37106, http://ark.intel.com/Compare.aspx?ids=47924,37106,
If you need more detailed buying recommendations I would suggest contacting any of our Authorized Intel® Distributors.
You can find a list of Authorized Intel® Distributors at:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm
Thank you for the reply.
I checked the intel web site. but i am not able to make the decision. In some aspects 5550 seems better and in some 5630.
So plz help here...
DSilv11
Valued Contributor III
That is a tough decision. Either one would get the job done.
Looking at one benchmarking site, http://www.cpubenchmark.net/multi_cpu.html http://www.cpubenchmark.net/multi_cpu.html
The x5550 has the lead in preformance, ranked 27 out of 173, being a faster processor and using faster memory (assuming your memory support 1333)
The E5630 raked 37 out of 173, you get more cache so it won't have to hit memory as often and the power draw is 15W less (30 watts for 2) so you save on your power bill. Price wise I see both on Newegg with the E5630 running much less so you save money their too.
So it comes down to personal choice,
Which is more important to you, cost or a slight edge in proformance?
