I'm pretty a newbee in the uClinux stuff on NIOS-II. My complements for this forum. I have the uClinux working and running on my Altera Cyclone board. I'm very exited about it, but I'm still not able to compile my own C program for uClinux and let it run on the NIOS. Can somebody please give me a tip or and example how to complile a simple program for uClinux and how to get it running on my demoboard? Thanks, Mr_IbanezLink Copied
What type of errors are you getting? Is it a compile time error or are you not sure how to get it up to the board?
--- Quote Start --- originally posted by ken@Jan 21 2005, 02:28 PM what type of errors are you getting? is it a compile time error or are you not sure how to get it up to the board? --- Quote End --- I couldn't get my own C file on the kernel. I allready solved the problem, the problem was in my makefile which wasn't right, and because of that, the building process didn't succeed. After building my linux -c application, I put the .exe file in directory etc of the filesystem and than I uploaded the filesystem to the nios and it works. So the make file was the bottleneck.
