12609 Discussions
Downloading ELF Process failed- Nios II quartus 19.1
eamun1
Hello, I have read threads about this issue but none of the proposed solutions solved my problem.
I'm facing issues when I tried to download the sw to the NIOS processor, the error message says Downloading ELF Process failed. I thought it was some mistake I had when creating the fpga project but I double check the design and it's good. I'm using the On-chip memory RAM for the NIOS II. I'm using the evaluation kit Cyclone 10GX from Intel.
-compile the design with quartus 19.1 Eval Board
-Flash the SOF
-Try with NIOS II quartus 2018 and NIOS 2019 (to check if that was the problem)
-Create a new project and bsp template with Hello world Small
-Compile the Project
-When in the Run configuration tab the message Connected system ID I tried with ignore mismatched ID and time stamp
-Run and error message:  Downloading ELF Process failed.
-Inside NIOS Command Shell try jtagconfig and I can see nios ii processor correctly detected.
-I followed this tutorial to disable the drivers signature Verification in windows 10 https://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/  so I can use the quartus 19 blaster-II drivers
-I also  follow this Troubleshooting guide cause at the beginning the NIOS eclipse IDE on quartus 19 was not even starting https://www.intel.com/content/www/us/en/support/programmable/articles/000086893.html
-I reinstall all the software and tools
EBERLAZARE_I_Intel
Did you install WSL?:
https://www.intel.com/content/www/us/en/support/programmable/articles/000074066.html
It may be due to WSL not being installed or with the design, can you try one of the design below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/edh_ed_handbook.pdf
I did a fresh Quartus and Nios II install, and install WSL and tried one of the design above, it is working fine.
EBERLAZARE_I_Intel
Any follow up from your side?
