12611 Discussions
Error when building project in eclipse
I am having problem when I build project in eclipse. I already build the Application and BSP Project. I right click the CRC_Accelerator_bsp software project and choose build project to build the board support package. When that build completes, I right click the CRC_Accelerator application software project and choose build project to build the Nios II application. That is when I get the error. The error says: make: *** [obj/default/ci_crc.o] Error 1
Can anybody help me? I have attached the screenshot. Is the problem with the source code? How do I know what is wrong exactly?
could you give a screenshot from the console output?
There are no outputs in the console. It's totally blank.I can only see error and it is as in the screen shot I attached. Why is wrong?
It is hard to look into the crystal ball without some more details, but let me try:
-right click to the BSP and click to regenerate the BSP
-Compile the Project (not BSP)
-Run as NIOSII
Does a simple Hello-World-Example work?
Please also see [1]
[1] https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/tt/tt_nios2_hardware_tutorial.pdf
A simple hello world example works but there is this error when I try to run configuration: Connected system ID hash not found on target at expected base address. My board is connected.
Why this error now?
In run configurations select the following options:
Ignore mismatched system ID
Ignore mismatched system timestamp
Try this. Also see if you included the system ID block in your SOPC/qsys design. (I think it's optional, but I usually include this anyway)
I get this output in the console:
**** Build of configuration Nios II for project Hello_World2 ****
make all
Info: Building ../Hello_World2_bsp/
make --no-print-directory -C ../Hello_World2_bsp/
Makefile not up to date.
C:/Users/Nanthini/Desktop/CRC_Acceleration_Example_Design/CycloneII/CRC_System.sopcinfo has been modified since the BSP was generated.
Generate the BSP to update the Makefile, and then build again.
To generate from Eclipse:
1. Right-click the BSP project.
2. In the Nios II Menu, click Generate BSP.
To generate from the command line:
nios2-bsp-generate-files --settings=<settings file> --bsp-dir=<target bsp files directory>
make[1]: *** [public.mk] Error 1
make: *** [../Hello_World2_bsp/-recurs-make-lib] Error 2
**** Build Finished ****
It says "Launching New Configuration" has encountered a problem.
Downloading ELF process failed.
And how do I see if I included the system ID block in my SOPC/qsys design?
Do you read your post before posting?
Do this:
Hi all.
I'm facing similar issue while Running 'Nios II Hardware' after building a simple hello_world_small project in Eclipse. Please find the attachment for details and kindly help in resolving the same.
Thanks in advance.
