12743 Discussões
Nios II Software Build Tools for Eclipse freezes from Java error
KEhle3
Principiante
1.923 Visualizações
I'm using Nios II Software Build Tools for Eclipse (Eclipse IDE for C/C++ Developers, Mars.2 Release (4.5.2), Build id: 20160218-0600) as part of Quartus Prime (Version 18.0.0, Build 614 04/24/2018 SJ Standard Edition).
Occasionally, the Nios II Eclipse IDE will just freeze, sometimes even when sitting idle. An Eclipse pop-up appears showing that a Java error occurred (see Nios_II_Software_Build_Tools_for_Eclipse_Java_error.png attachment). Is this a known issue? Is there a fix for it?
3 Respostas
Ahmed_H_Intel1
Funcionário
1.543 Visualizações
Can you check the following if this will solve your problem?
Check the workaround available here and let me know if this solves the issue.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/why-does-my-plateform-designer-window-just-flash-and-disappear-.html
KEhle3
Principiante
1.543 Visualizações
This workaround is for Platform Designer; however, my issue is with Nios II Software Build Tools for Eclipse. Additionally, this workaround is for Quartus Prime version 17.1 update 2 and earlier; however, I'm using Quartus Prime version 18.0.0. The Java error looks very different, but I looked into the workaround/fix anyway. No (good) luck. Anything else seem like a possible fit?
Ahmed_H_Intel1
Funcionário
1.543 Visualizações
Have you tried another version of Quartus?
Responder
