missing socal folder
Hi!
I will be using DE1-SOC board for my bachelor's degree and Im learning on how to use it. I noticed that user's manuals are for version 13 of Quartus and current version is version 15. I have already encountered some differences that puzzled me but I managed to solve them with a bit of googling. Now Im at FPGA-HPS project and I get an error from command shell:
$ makearm-linux-gnueabihf-gcc -static -g -Wall -IE:/Programs/altera/15.0/embedded/ip/ altera/hps/altera_hps/hwlib/include -c main.c -o main.o main.c:6:25: fatal error: socal/socal.h: No such file or directory # include "socal/socal.h" ^ compilation terminated. make: *** Error 1
I noticed that there are now two folders there: soc_a10 and soc_cv_av, which both include the missing files. What do these two folders mean? Which one should I use? Do I fix the header to match the new folder configuration?
Thank you for help!
TO_BE_DONE
TO_BE_DONE
The new 15.0 makefiles for hwlibs expect the ALT_DEVICE_FAMILY variable to be set to "soc_cv_av" or "soc_a10".
ALT_DEVICE_FAMILY ?= soc_cv_av
CFLAGS := -g $(OFLAG) -Wall -Werror -std=c99 $(MULTILIBFLAGS) -I$(HWLIBS_ROOT)/include -I$(HWLIBS_ROOT)/include/$(ALT_DEVICE_FAMILY) -D$(ALT_DEVICE_FAMILY)
ALL_HWLIBS_SRC = $(wildcard $(HWLIBS_ROOT)/src/hwmgr/*.c) $(wildcard $(HWLIBS_ROOT)/src/hwmgr/$(ALT_DEVICE_FAMILY)/*.c $(wildcard $(HWLIBS_ROOT)/src/utils/*.c))
On the CFLAGS, you need to add the soc_cv_av or soc_a10 directories to the includes with -I and define either -Dsoc_cv_av or -Dsoc_a10. The ALL_HWLIBS_SRC variable above finds all the .c files in all the directories.
Thank you very much for help! The instructions seem to be for version 13 and I was a little bit confused by some changes.
I am trying to make the my_first_hps-fpga tutorial given in altera de0 nano soc cd. firstly i got above same error that was with social file. now get another error as below. i tried above lines
in make file but now i get another error.
$ make
arm-linux-gnueabihf-gcc -g -Wall -Werror -std=c99 -I/include -I/include/soc_cv_av -Dsoc_cv_av -c main.c -o main.o
main.c:5:19: fatal error: hwlib.h: No such file or directory
# include "hwlib.h"
make: *** [main.o] Error 1
Did you manage to solve the problem G.Ornil ? I have the same problem.
Changes to the make file are in red - define ALT_DEVICE_FAMILY, then in CFLAGS statement add -D definition. Still assumes include statements have /soc_cv_av added to them.
TARGET = hps_gpio#
CROSS_COMPILE = arm-linux-gnueabihf-
CFLAGS = -g -Wall -I ${SOCEDS_DEST_ROOT}/ip/altera/hps/altera_hps/hwlib/include -D$(ALT_DEVICE_FAMILY)
LDFLAGS = -g -Wall
CC = $(CROSS_COMPILE)gcc
ARCH= arm
build: $(TARGET)
$(TARGET): main.o
$(CC) $(LDFLAGS) $^ -o $@
%.o : %.c
$(CC) $(CFLAGS) -c $< -o $@
.PHONY: clean
clean:
rm -f $(TARGET) *.a *.o *~
I still have the same problem. :'(
--- Quote Start ---
--- Quote End ---
I gave up using linux, you can use nios 2 or HPS for soc fpga. still nios 2 is easier it has many tutorials than HPS
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
I have the same problem and can not find a solution although I have followed everything closely in this discussion.
I am using a DE0-Nano-SoC board and I wanted to bring the demo-Software in the Folder
SoC/Beispiele/HPS_CONTROL_FPGA_LED/software up and running.
Error:
In file included from main.c:7:0:
D:/intelFPGA_pro/18.0/embedded/ip/altera/hps/altera_hps/hwlib/include/hwlib.h:56:2: error:# error You must define soc_cv_av or soc_a10 before compiling with HwLibs
main.c:8:25: fatal error: socal/socal.h: No such file or directory
Has anyone found a solution?
Many Thanks in advance, Reinhard
RRuiz5
Working Makefile for 18.1 version
TARGET = my_first_hps   ALT_DEVICE_FAMILY ?= soc_cv_av   SOCEDS_ROOT ?= $(SOCEDS_DEST_ROOT)   HWLIBS_ROOT = $(SOCEDS_ROOT)/ip/altera/hps/altera_hps/hwlib     CROSS_COMPILE = arm-linux-gnueabihf-   CFLAGS=-g -Wall -D$(ALT_DEVICE_FAMILY) -I$(HWLIBS_ROOT)/include/$(ALT_DEVIVE_FAMILY) -I$(HWLIBS_ROOT)/include/ -I $(HWLIBS_ROOT)/include/soc_a10/         LDFLAGS= -g -Wall CC = $(CROSS_COMPILE)gcc ARCH= arm   build: $(TARGET)   $(TARGET): main.o $(CC) $(LDFLAGS) $^ -o $@   %.o : %.c $(CC) $(CFLAGS) -c $< -o $@   .PHONY: clean   clean: rm -f $(TARGET) *.a *.o *~
RRuiz5
This Makefile is working for me
HThie5
@RRuiz5​ it the soc_a10 similar to the soc_cv_av (aka Cyclone V as on the de0 nano board) ?
