12742 ディスカッション
"Exec format error" in HelloWorld-Linux example
名誉コントリビューター II
2,628件の閲覧回数
In 13.1 version of SoC EDS this example works normal 2 month ago, and now in 14.0 fails.
I make all described in "Getting Started with Linux Application Debugging" from ug_soc_eds.pdf, and on final stage see dialog "Connection failed" with text:
--- Quote Start ---
Unable to connect to LinuxAppDebug_DevKit
Reason: Failed target configuration:
gdbserver exited unexpectedly see the App Console for further information
--- Quote End ---
In App Console:
--- Quote Start ---
Preparing the debug session
# cd /home/root
# export LD_LIBRARY_PATH=".:/home/root:$LD_LIBRARY_PATH"
# gdbserver :5000 "/home/root/hello.o"
Process /home/root/hello.o created; pid = 279
Cannot exec /home/root/hello.o: Exec format error.
Child exited with status 127
No program to debug. GDBserver exiting.
--- Quote End ---
I think that my SD-card have old Linux-version for new compilers in SoC EDS, fill it with new 14.0-image through Win32DiskImager.exe -- error remain.
Delete all project and reimport it from archive, recompile -- similarly.
I see a file hello.o in /home/root (Remote System Explorer view), copy it back to Windows filesystem -- it is equal with my in project, 2792 bytes. Delete it, run configuration again -- it appears in /home/root: Eth-link is working !
Where may be problem ? In 13.1 this example was debugged normal.
0 件の賞賛
1 返信
名誉コントリビューター II
1,764件の閲覧回数
I have mistake -- run hello.o instead hello. :)
--- Quote Start ---
--- Quote End ---
And all 99 Linux Users not see this...
In Linux ARM processor works faster by order of magnitude ! Or 2 orders in comparison with Baremetal :)
May anybody say why ? And how i will do in Baremetal to increase clock to 925 MHz ?
返信
