16 bit SRAM
Dear all,
I have a problem that is maybe already seen by one of you:
I have generated a NIOS core with a 256Kx16 bit SRAM interface. The SRAM module is connected to the avalon tri-state bridge.
Address = (0-17)
Data = (0-15)
WRn = 1 bit
RDn = 1 bit
CSn = 1 bit
BHEn=1 bit
BLEn = 1 bit
The generation of the nios core completes without errors. But after I have finished my design fitting .. I get following warning
SRAM_Address(0) is synthezised away
Any idea why?... Is the address mapping between the avalon bridge and the sram module wrong?
--- Quote Start ---
originally posted by karel van haver@Dec 1 2006, 12:07 PM
dear all,
i have a problem that is maybe already seen by one of you:
i have generated a nios core with a 256kx16 bit sram interface. the sram module is connected to the avalon tri-state bridge.
address = (0-17)
data = (0-15)
wrn = 1 bit
rdn = 1 bit
csn = 1 bit
bhen=1 bit
blen = 1 bit
the generation of the nios core completes without errors. but after i have finished my design fitting .. i get following warning
sram_address(0) is synthezised away
any idea why?... is the address mapping between the avalon bridge and the sram module wrong?
regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19768)
--- quote end ---
--- Quote End ---
Read the building memory subsystems (http://www.altera.com/literature/hb/qts/qts_qii54006.pdf) section in the SOPC Builder handbook. Look at table 9-1... You&#39;re welcome to either modify the existing Europa-based (Perl HDL generation) SRAM component or generate your own using the Component Editor/Builder.
- slacker
--- Quote Start ---
originally posted by slacker+dec 1 2006, 04:13 pm--><div class='quotetop'>quote (slacker @ dec 1 2006, 04:13 pm)</div>
--- quote start ---
<!--quotebegin-karel van haver@Dec 1 2006, 12:07 PM
dear all,
address = (0-17)
data = (0-15)
wrn = 1 bit
rdn = 1 bit
csn = 1 bit
bhen=1 bit
blen = 1 bit
regards
--- quote end ---
--- Quote End ---
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19769)</div>
[/b]
--- Quote End ---
Slacker,
Thanks a lot for the spec sheet. So, my thought that the mapping between the SRAM address and the tri state address pinning wasn&#39;t correct and is indeed explained in the spec sheet.
So, instead of connecting SRAM A0 pin to tri-state-bridge-address0, I should connect SRAM A0 to tri-state-bridge-address1 and keep tri-state-bridge-address0 unconnected.
Karel
TO_BE_DONE
