12748 Discussions
A newbie needs help with ethernet in NiosII
Hi all!!!!
I'm starting with NiosII processor and I need some help. I want to send/receive some data to/from a PC via ethernet. I was using NiosI with no problems, but I can not migrate my code to NiosII by any means (I've tried to do it using microC and a couple of threads instead of my initial single threaded code) so I'm planning to start again from zero.
The question is: Is there any simple way (I mean single threaded, and with no OS) to send/receive via ethernet??? Something like nr_plugs_send()???. I`ve tried the standalone lwip, but there are some things that I can&#39;t understand (sorry I&#39;m a hardware man http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif )
Thanks to all!!!!!!
Hi again!!!!
Has anybody succesfully used the Nios plugs library in NiosII??? I&#39;ve been searching for the forum and can&#39;t find an answer.
No one???
I&#39;m desperate, please someone can help me??? I&#39;m lost in documentation!!!!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
Seriously now, I just need to send and recieve 32/16 bits integers via ethernet in a simple way no protocols, threads or os needed, but I&#39;m a mess pgrogramming http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif .
Thanks in advance!
I&#39;m not saying it will work, but have you tried changing
generate_sdk = "0";
to
generate_sdk = "1"; in your SOPC Builder project&#39;s PTF file?
I think this should generate a "Nios Classic" style SDK, where you&#39;ll, at least, have a shot at getting things to work. A quick "grepping" for plugs in the various components directory indicates that the source code is still there...as of 6.1.
Good luck!
- slacker
UPDATE:
Two more flags need to be set, as well:
legacy_sdk_support = "1"; allow_legacy_sdk = "1";
--- Quote Start ---
originally posted by slacker@Mar 8 2007, 06:50 PM
i&#39;m not saying it will work, but have you tried changing
generate_sdk = "0";
to
generate_sdk = "1"; in your sopc builder project&#39;s ptf file?
i think this should generate a "nios classic" style sdk, where you&#39;ll, at least, have a shot at getting things to work.  a quick "grepping" for plugs in the various components directory indicates that the source code is still there...as of 6.1.
good luck!
- slacker
update:
two more flags need to be set, as well:
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22127)</div>
--- Quote End ---
Thanks for your answer slacker!!!!! I`m trying it right now, hope it works.
Just one more question..... Do you know if a NiosI can be loaded into a StratixII board??? I&#39;ve tryied it many times, but never succeded. Using Nios with a StritixII board will solve all my problems, since my project is working with no problems on a StratixI with NiosI.
Thanks again!!!
I&#39;m a disaster! I can&#39;t make it work http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif .
Anyway, this is the answer i got from altera when i asked them:
"Unfortunately, there is no resource available about using the Plugs Ethernet Library on a NiosII system.
Standalone lwip is a solution wich is no RTOS and single threaded. You can download it from www.niosforum.com
Seems like I will have to learn how to use the standalone lwip http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif . By the way, anyone knows a good source of documentantion and/or examples for standalone lwip??
Thanks!
