when I run ./build for building the environment
the link-HTTP problem happened,should I download the 200M patch files or If I skip it,can it works? It's appreciate if any one can help.Link Copied
--- Quote Start --- originally posted by gaobing@Jun 29 2006, 11:36 AM when i run ./build for building the environment
the link-http problem happened,should i download the 200m patch files or if i skip it,can it works?
it's appreciate if any one can help.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16498)
--- quote end ---
--- Quote End --- I don't recommend the buildroot for newbies now. Follow the new nios wiki, step 1-3. http://nioswiki.jot.com/%c2%b5clinux (http://nioswiki.jot.com/%c2%b5clinux)
