i followed the passage on niosWiki:
binarytoolchain (http://www.niosforum.com/pages/forum.php?cat_id=5) i run the command in terminal: ********************* su -# your root passwd tar jxf /home/hippo/download/nios2gcc.tar.bz2 -C / exit *********************** after that, i found the cross gcc tools in "/opt/nios2", then i opened the file".bash_profile" and added "PATH=$PATH:/opt/nios2/bin:$HOME/bin" into it. but when i run the command "nios2-linux-uclibc-gcc -v", the terminal showed followed error: "bash:nios2-linux-uclibc-gcc -v : can't find the command", i hope someone can help me! thanksLink Copied
after you change the .bashprofile, you need to logout and login again.
--- Quote Start --- originally posted by hippo@Apr 4 2007, 12:16 AM after you change the .bashprofile, you need to logout and login again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22782)
--- quote end ---
--- Quote End --- thanks, hippo.but i still can't run the command "nios2-linux-uclibc-gcc -v" after logining again. and my .bash_profile's content is : ======================================# ~/.bash_profile: executed by bash(1) for login shells.# see /usr/share/doc/bash/examples/startup-files for examples.# the files are located in the bash-doc package. # the default umask is set in /etc/login.defs# umask 022 # include .bashrc if it exists if [ -f ~/.bashrc ]; then . ~/.bashrc fi # set PATH so it includes user's private bin if it exists if [ -d ~/bin ] ; then PATH=~/bin:"${PATH}" fi PATH=$PATH:/opt/nios2/bin:$HOME/bin ======================================= is there any problem whit it? hope you can help me ,thanks! by the way, my linux-OS is Ubuntu6.1
i have solved the problem, i setted the PATH in the file ".bashrc", adding following text:# ###
export PATH="$PATH:/opt/nios2/bin:$HOME/bin"# ### then i can run the command "nios2-linux-uclibc-gcc -v ". i think the PATH settings vary from different linux OS, maybe! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
