12748 Discussions
About the uclinux starter and memory allocation
dear all,
when i do uclinux according to hippo, now i can run uclinux in my target board(nios2,FLASH8MB(0X000000-0X7FFFFF),SDRAM(8MB)0X800000-0XFFFFFF),but i still don't understand where the zImage file download to,and how does the uclinux work and how does the memory space use?
in my target board:
0x000000|------------------|
------------|8MB FLASH ---- |
0x7FFFFF |-------------------|
0x800000|-------------------|
-----------|8MB SDRAM ----|
0xd00000|-------------------| <-----kernal config 0x500000+0x800000,why ??
0x0FFFFFF|-------------------|
0x1000000|-- NIOS II ------|
0x10007FF |------------------|
IN THE SYSTEM THE RESET ADDRESS 0X000000,EXECPTION ADDRESS 0X800020
COULD YOU TELL ME HOW DOES THE UCLINUX WORK WHEN THE SYSTEM POWER ON?
You didn&#39;t program the flash at 0x000000 yet. You can program the flash, so that will start after power-on without data blaster download/cable.
http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/flashprogrammer
NOTE, you should not use jtag uart in this case, or it will hang until you run nios2-terminal. you should use serial uart instead.
The nios2-download will load the zImage to (0x800000 + 0x500000), and start exec at this address, ie 0xd00000.
The zImage will uncompress the linux kernel (gziped in zImage) to 0x800000. And start exec at 0x800000.
