12748 Discussions
Altera RO zip file system problem with latest IDE
Hi
I have used this component for years now. Lately I finally upgraded my old NIOSII IDE 7.2 environement to flashy new 10.1 and several problems occured:
Back in 7.2 the output was a file called filesys.flash. I am no longer able to create filesys.flash when using 10.1, even when using the web server app example.
In fact, I can't even find where to put the name of the zip file archive?
The BSP editor asks for 3 parameters only: Mount point, Base address and Offset. Thats ok, but BSP editor does not ask for the name of the zip file?
In the web server app example, the zip file is named r0_zipfs.zip and is put in subdir .\system. For me its like its never included into the make, because nothing happens if I remove or rename the file ?
Read the UM but didn't help much.
Anyone having a clue?
Jan
