12748 Discussions
Any experience with ping_app on niche-stack
Hello all,
has anyone experience with the ping-app within the niche-stack?
How can a ping be started?
How can i get the ping statistics?
How to setup parameters like detination ip, timeout, ttl, data-size, etc?
Is there any example code?
:confused:
Do you mean to ping niche stack from an external device or do you want niche stack to send a ping? Probably the second one, since the first one is the basic way of operation.
I never tried pining from iniche but I think it is quite simple.
Try with send_arp() function.
You'll find it in et_arp.c file in
/altera.components/Nios II Software Packages/altera_iniche/UCOSII/src/ip/
If not this function, look in other files in the same ip directory.
