12745 Discussions
Ask for help about on-chip memory
Hi everyone
When I used the on-chip memory,I meet the error as following:
D:/QuartusII_project/nios_turorial_2/lights_syslib/Debug/liblights_syslib.a(alt_dev_llist_insert.o)(.text+0xdc): In function `alt_get_errno':
/cygdrive/d/altera/kits/nios2_51/components/altera_hal/HAL/inc/sys/alt_errno.h:81: Unable to reach errno (at 0x00000024) from the global pointer (at 0x00009a0c) because the offset (-39400) is out of the allowed range, -32678 to 32767.
I want to konw how to deal with the errors.Waiting for help!
You should try using the search feature of the forum. Search for "global pointer". There is a lot of information on this topic.
In any case, the -G0 (that's zero) compiler flag should prevent data from being linked into .sdata and/or .sbss.
Cheers,
- slacker
Oh,I change the memory size to 40K,the problem is solved.
But,the new problem is coming.
when I run as niosII-Hardware,the message is as following:
Using cable \"USB-Blaster [USB-0]\", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
My code is so simple,as following:# include <stdio.h>
int main()
printf(\"Hello from Nios II!\\n\");
return 0;
Why?Could you help?
