Hello everybody,
I am using Quartus II and NIOS II version 5.0. Does anyone experienced problems with the autogeneration of base addresses in the SOPC builder? When I have only one CPU with some modules (lcd, led etc.) it goes well, but when i have more than one CPU and adding some mutexes and stuff the SOPC builder generates the base addresses for me but there are a lot of conflicts. As a matter of fact I saw base addresses that were equal http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif (of modules connected to the same CPU!). Any tips? JMastron.Link Copied
Hi jmastron,
r u sure they are connected to the same bus master?- Mark as New
Yes, otherwise it may not show the confict messages.
I quess that if I say that it must generate the base addresses automatically, the error messages of "same baseaddresses" should go away!- Mark as New
This sounds like a known problem. The work-around is to manually assign the base addresses.
