12748 Discussions
BSP Editor generate fails with VIC
I generated a qsys design with NIOS2 and a VIC (Vectored Interrupt Controller).
I then created a NIOS2 application and bsp (used the small hello world template).
The code compiles fine but I wanted to dig deeper into the interrupt handling code and then I noticed that in the drivers section of the bsp, the 'altera_vic_0_vector_tbl.S' file is empty which seemed strange.
I ran the bsp editor and made sure all parameters made sense and then hit 'generate'. The result is an error message: 'TCL script "C:\altera\11.0\ip\altera\altera_vectored_interrupt_controller\top\callbacks.tcl vic_0 ..." error: expected integer but got ""
Can anyone shed light on this?
Thanks, Amit
I ran into the same problem.
It seems that interrupts and qsys don't live in harmony.
I have a complex system which runs ok when using SOPC but when i create the same in qsys then i get tremendous interrupt related issues.
I also wondered why the interrupt custom instruction has been discarded with qsys.
I would recommend to post this issue as a support request to Altera.
let me know any progress...
regards
