Boot problem DE2-70 mmu
I have a problem to boot the Linux kernel with MMU on DE2-70 board.
I changed the design in SOPC followed instructions at http://www.alterawiki.com/wiki/creating_a_nios_ii_design_with_an_mmu
However the Linux isnt booting. Bellow is output from console
bash-3.1$ nios2-download -g linux.initramfs.gz;nios2-terminal.exe Using cable "USB-Blaster ", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 5277KB in 92.0s (57.3KB/s) Verified OK Starting processor at address 0xC4000000 nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster ", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
then nothing happen
Attached is also my SOPC design - I modified one from the demonstrations
Any idea what can be the problem?
Thank You
