12747 Discussions
Byteblaster driver for Linux 2.6
Has anyone successfully ported the ByteblasterII device driver to the version 2.6 kernel ?
Would appreciate any info on how this can be achieved.
I have managed to generate the byteblaster.ko file but find that insmod fails with the following error:
error inserting 'byteblaster.ko': -1 device or resource busy
This error is returned by devfs_register_chrdev but I'm not sure why this would occur, no other devices are connected to the port. Any suggestions ?
thanks
Here is a patch for byteblaster on 2.6:
diff -urN byteblaster.orig/byteblaster.c byteblaster/byteblaster.c
--- byteblaster.orig/byteblaster.c 2004-11-30 12:11:14.000000000 +0100
+++ byteblaster/byteblaster.c 2005-02-09 12:10:24.000000000 +0100
@@ -66,6 +66,7 @@
# include <linux/module.h>
# include <linux/kernel.h>
# include <linux/devfs_fs_kernel.h>
+#include <linux/fs.h>
# include <linux/slab.h>
# include <linux/smp_lock.h>
# include <linux/sched.h>
@@ -88,7 +89,7 @@
struct byteblaster_t {
struct pardevice * dev;
unsigned long flags;
- devfs_handle_t devfs_handle;
+ dev_t devfs_handle;
struct semaphore port_mutex;
char * read_fifo;
@@ -419,10 +420,10 @@
return;
sprintf (name, "byteblaster%d", i);
- byteblaster.devfs_handle = devfs_register (null, name,
- devfs_fl_default, byteblaster_major, i,
- s_ifchr | s_irugo | s_iwugo,
- &byteblaster_fops, null);
+ byteblaster.devfs_handle = NULL; //devfs_register (NULL, name,
+// DEVFS_FL_DEFAULT, byteblaster_major, i,
+// S_IFCHR | S_IRUGO | S_IWUGO,
+// &byteblaster_fops, NULL);
printk(KERN_INFO "byteblaster%d: using %s.\n", i, port->name);
@@ -441,7 +442,7 @@
if (byteblaster.dev != null && byteblaster.dev->port == port) {
parport_unregister_device(byteblaster.dev);
- devfs_unregister(byteblaster.devfs_handle);
+ //devfs_unregister(byteblaster.devfs_handle);
byteblaster.dev = NULL;
byteblaster.devfs_handle = null;
@@ -468,7 +469,7 @@
byteblaster.read_fifo = NULL;
- err = devfs_register_chrdev(byteblaster_major, "byteblaster", &byteblaster_fops);
+ err = register_chrdev(byteblaster_major, "byteblaster", &byteblaster_fops);
if (err < 0)
return err;
@@ -488,12 +489,12 @@
parport_unregister_driver (&byteblaster_driver);
- devfs_unregister_chrdev(byteblaster_major, "byteblaster");
+ unregister_chrdev(byteblaster_major, "byteblaster");
for (i = 0 ; i < BYTEBLASTER_MAX ; i++)
if (byteblaster.dev != null) {
diff -urN byteblaster.orig/Makefile byteblaster/Makefile
--- byteblaster.orig/Makefile 2004-11-30 12:11:14.000000000 +0100
+++ byteblaster/Makefile 2005-02-09 14:42:16.222653771 +0100
@@ -15,25 +15,38 @@
# This is the default location of the
# VER = $(shell uname -r)
# INCLUDEDIR=/lib/modules/$(VER)/build/include
-include .config.make
+#include .config.make
-CFLAGS= -D__KERNEL__ -DMODULE -D__SMP__ -O3 -Wall -I$(INCLUDEDIR)
+#CFLAGS= -D__KERNEL__ -DMODULE -D__SMP__ -O3 -Wall -I$(INCLUDEDIR)
# Comment out the next line if you don&#39;t want kernel symbol versioning.
-CFLAGS += -DMODVERSIONS -include $(INCLUDEDIR)/linux/modversions.h
+#CFLAGS += -DMODVERSIONS -include $(INCLUDEDIR)/linux/modversions.h
-OBJS = byteblaster.o
+#OBJS = byteblaster.o
-byteblaster.o : byteblaster.c Makefile
+ifneq ($(KERNELRELEASE),)
+ obj-m := byteblaster.o
-install: byteblaster.o jtagd-init
+else
+ VER := $(shell uname -r)
+ KDIR := /lib/modules/$(VER)/build
+ PWD := $(shell pwd)
+default:
+ $(MAKE) -C $(KDIR) SUBDIRS=$(PWD) modules
+endif
+#byteblaster.o : byteblaster.c Makefile
+install: byteblaster.ko jtagd-init
install -d /lib/modules/$(VER)/kernel/misc/
- install -c byteblaster.o /lib/modules/$(VER)/kernel/misc/byteblaster.o
+ install -c byteblaster.ko /lib/modules/$(VER)/kernel/misc/byteblaster.ko
install -c jtagd-init /etc/rc.d/init.d/jtagd
/sbin/chkconfig --add jtagd
/sbin/depmod -aq
/etc/rc.d/init.d/jtagd start
clean:
- rm *.o
+ rm -f *.ko *.o .*.cmd byteblaster.mod.c
+ rm -rf .tmp_versions
Thanks, I will give it a try.
