12748 Discussions
C code syntax coloring in NIOS Eclipse editor
Here below how C source code appears in Eclipse editor. 2nd screenshot - the same code in Notepad++.
Is there some option that allows highlight C/C++ syntax in Eclipse editor.
http://www.alteraforum.com/forum/attachment.php?attachmentid=13310&stc=1
http://www.alteraforum.com/forum/attachment.php?attachmentid=13311&stc=1
Finally I've get it colored. For this I needed to close/open the source file.
But initially, when I've created a new file and then pasted the source code from another file, the code appeared in BW.
Probably a bug (insignificant nevertheless)
