C2H compiling error
I built my C code with cycloneII SOPC design in NiosII IDE without any problem and I can see the result in ModelSim..but when I want to accelerate a function(loopH) of my code using C2H,it doesn't build the whole code any more.
and find an error in a line contained this code:
unsignedchar * str;
the error shown in Problems TAB:
C2H C2H ERROR: "c:/altera/91/nios2eds/components/altera_avalon_c_hardware_accelerator/lex_and_yacc/c2h_cparse.exe" "G:/hello_world_0/Debug/obj/hello_world.c2h_pre" hello_world_0 line 0 1265494093645 72
PARSE ERROR, ../hello_world.c line 72 column 13 hello_world_0 hello_world.c line 72 1265494093645 71
NOTE:My project name was Hello world
_______________________________________________________
how can I find an alternative for this part of code which C2H can support and translate it?:confused:
here is the LINK to the complete C code which I used in my poject:
pooya-ww.persiangig.com/Project/sha1%20(2).c
Is the variable defined in the middle of a block?
C2H doesn't support that C99 'feature' and requires that all variable definitions be at the start of program blocks.
thank you dsl..you were right.I shifted all of the variable definitions to the start of program blocks and that error vanished.but after building the project I faced to another error which doesn't point to my code lines..!!
ERROR(PROBLEMS TAB):
make: *** [c2h_hdl-t] Error 254
contexts of (console tab):
Info: Wrote G:/Nios/standard/NiosII_cycloneII_2c35_standard_sopc.sopcinfo
Info: NiosII_cycloneII_2c35_standard_sopc: Wrote G:/Nios/standard/NiosII_cycloneII_2c35_standard_sopc.html
Info: NiosII_cycloneII_2c35_standard_sopc: Generating QIP file.
Info: Info: *******************************************************************
Info: Info: Running Quartus II Shell
Info: Info: Version 9.1 Build 222 10/21/2009 SJ Full Version
Info: Info: Copyright (C) 1991-2009 Altera Corporation. All rights reserved.
Info: Info: Your use of Altera Corporation's design tools, logic functions
Info: Info: and other software and tools, and its AMPP partner logic
Info: Info: functions, and any output files from any of the foregoing
Info: Info: (including device programming or simulation files), and any
Info: Info: associated documentation or information are expressly subject
Info: Info: to the terms and conditions of the Altera Program License
Info: Info: Subscription Agreement, Altera MegaCore Function License
Info: Info: Agreement, or other applicable license agreement, including,
Info: Info: without limitation, that your use is for the sole purpose of
Info: Info: programming logic devices manufactured by Altera and sold by
Info: Info: Altera or its authorized distributors. Please refer to the
Info: Info: applicable agreement for further details.
Info: Info: Processing started: Tue Feb 09 01:24:06 2010
Info: Info: Command: quartus_sh -t sopc_add_qip_file.tcl
Info: Info: Evaluation of Tcl script sopc_add_qip_file.tcl was successful
Info: Info: Quartus II Shell was successful. 0 errors, 0 warnings
Info: Info: Peak virtual memory: 102 megabytes
Info: Info: Processing ended: Tue Feb 09 01:24:06 2010
Info: Info: Elapsed time: 00:00:00
Info: Info: Total CPU time (on all processors): 00:00:00
Error: Can't create file G:/Nios/standard/NiosII_cycloneII_2c35_standard_sopc.ptf
Error: System generation failed.
Build completed in 157.569 seconds
I got the same error (make: *** [c2h_hdl-t] Error 254), anybody know what caused this error & how to solve this error?
thanks
