C2H questions, need help
Hi!
i've tried to implement an example to evaluate C2H. i've accelerated a function
named testalg. c2h compiles it, in the sopc builder everything is fine, the quartus flow doesn't report any errors, nor the C2H Register build log at Nios II IDE says anything. it looks everything fine, but
the result is always -1
here's the whole code
# include <stdio.h>
int testalg(int a, int b )
return a*a + b*b;
int main()
int sum = 0;
printf("sum before = %d\n",sum);
sum = testalg(5,5);
printf("sum after = %d\n",sum);
printf("should be 50\n");
return 0;
P.S. can i avoid the c2h compiler to restart the whole quartus flow, when i just
change something in the software project, and not in the acceleration function?
Thanks 4 reading
and it would be good, if someone can help me out
greetz Andreas
hi!
i&#39;ve solved the problem.
just in case someone else has the same problem in the future.
the problem was, that i was not sure if the c2h compiler, which starts the flow, also downloads the sof file.
and i also didn&#39;t recognise that i have to download the time limited sof file and not the standard sof file (i just have an evaluation license at the moment)
so far
merry xmas
Andreas
