CF IDE Support in kernel
I want to do the sample in Microtronix Reference Guide on page 33. Creating an Extended 2 Filesystem on a CompactFlash Card.
I create a new kernel project and configure the kernel for my cyclon board. (Altera EP1C20 Board).
If I build the kernel I get the follwing Messages:
Error *** [_all] Error 2 standart_kernel
Error *** [drivers/ide/ide.o] Error 1 standart_kernel
Error *** [drivers/ide] Error 2 standart_kernel
Error *** [drivers] Error 2 standart_kernel
Error error: `na_ide_ide' undeclared (first use in this function)[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] standart_kernel line 262
Error error: (Each undeclared identifier is reported only once[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] standart_kernel line 262
Error error: `na_ide_ide_irq' undeclared (first use in this funmake: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] standart_kernel line 313
Error *** [_all] Error 2 test_kernel
Error *** [drivers/ide/ide.o] Error 1 test_kernel
Error *** [drivers/ide] Error 2 test_kernel
Error *** [drivers] Error 2 test_kernel
Error error: `na_ide_ide' undeclared (first use in this function)[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] test_kernel line 262
Error error: (Each undeclared identifier is reported only once[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] test_kernel line 262
Error error: `na_ide_ide_irq' undeclared (first use in this funmake: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c] test_kernel line 313
Looks like your core does not have a CF component.
Thanks, now it works fine...
Mike http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
--- Quote Start ---
originally posted by mikesp@May 19 2005, 06:32 AM
thanks, now it works fine...
mike http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/biggrin.gif
--- Quote End ---
can you give me your compactflash component
