CFI Core Timing.
When I use custom flash that complies with the CFI specification, shoud I re-set the setup/wait/hold timing or use the default setting?
My flash is amd 2M*16-bit with 90ns.
In addition, the min-system that can test flash includes what components(do not use the standard altera provided).
Thank you.
