Hi
I have trouble with the sampling of ATA_SEL line during POR. I am trying to run the CFI in PC-ATA IO Mode using PIOs driving the CFI pins ( well most of them) Hence i am trying to Power off the CF Card and wait for a couple of seconds before switching the power on. I figured this should let me setup my ATASEL line to 1 and then Power on the chip, so that the chip would sample 1 on ATASEL and switch to PC-mem Mode. But even after Switching power off for 10 sec and then switching it back on, any registers i set previously are not getting reset to their Power on Defaults. What am i doing wrong ??? BTW i am using Nios Stratix Dev Kit 1s10 My code :--> void init() { printf("\nWaiting for card to be plugged in"); while(RD(CF_DETECT_BASE)==1) ; printf("\nCard Detected "); printf("\nPower Cycling Card"); WR(CF_ATASEL_BASE,1); WR(CF_POWER_BASE,0); printf("\nWaiting 10 Sec to take care of Leakage Currents"); usleep(10000000); //10 sec WR(CF_POWER_BASE,1); printf("\nRestarting:: Waiting 1 Seconds for CF Power Supply Ckt To Stabilise"); usleep(1000000); //1 sec WR(CF_RFU_BASE,0); WR(CF_IORD_N_BASE,1); WR(CF_IOWR_N_BASE,1); WR(CF_WE_N_BASE,1); WR(CF_ATASEL_BASE,0); WR(CF_CS_N_BASE,0); SW(CF_SPKR_BASE,0); SW(CF_DATA_BASE,0); while(RD(CF_SPKR_BASE)==0) ; printf("\nCard Powered up Successfully"); } regards PavanLink Copied
