12744 Discussões
CPU CYcle count Urgent Info Required
Colaborador honorário II
1.117 Visualizações
Hello All,
What are the ways to find the CPU cycle count ? as in Performance counter , using timestamp. But both of these are not working in my case.
Could anyone let me know the detailed settings in the SOPC builder along with Quartus settings to make this work.
or if there any other solutions apart from these , pls let me know .
Ravi MS
2 Respostas
434 Visualizações
This document contains this information for each core: http://www.altera.com/literature/hb/nios2/n2cpu_nii51015.pdf (http://www.altera.com/literature/hb/nios2/n2cpu_nii51015.pdf
Remember that these numbers do not factor in access times to other components or cache efficiency since this changes based on your system/algorithm.
434 Visualizações
My requirement would be get the cpu cycle count for a particular function or an application, are there any ways apart from the ones i had mentioned earlier.
Ravi MS
<div class='quotetop'>QUOTE (BadOmen @ Jul 20 2009, 10:01 PM) <{post_snapback}> (index.php?act=findpost&pid=23216)</div>
--- Quote Start ---
Remember that these numbers do not factor in access times to other components or cache efficiency since this changes based on your system/algorithm.[/b]
--- Quote End ---
Responder
