12748 Discussions
Can I compile the disambly code to executable?
Can I disamble an elf file into an assembly file and then compile this assembly file into an executable?
Thanks!
Hi Cloud,
If you're planning to use objdump/readelf, the output contains
extra information that isn't suitable for direct assembly ... but
you can get close ;-)
--Scott
I take it you are going to modify the code to make it more efficient. If that's the case you might want to just optimize the bottlenecks (if your code was big then you'll have a lot of work ahead of you to decipher what the compiler does to your code (use very little optimization so that you don't get completely lost))
Cheers
If you are indeed trying to hand-optimize the assembly code created by the compiler,
I recommend that you use the -S option to gcc. Instead of creating a .o file, it will
generate a .s file containing the assembly code that it generated.
You can then edit this file and then assemble it with gcc.
