12748 Discussions
Can I update and save file when n2linux running?
hi all:
I want to update some files( for example: rework the prime IP setting in
`etc/inittab) when the nios2 uclinux is running. Then reset the DVB, the uclinux
will confing the system bases the updated inittab file.
I think to I can use these function :file_open, file_read, file_write to rework the
file of I want to rework. But the nios2 uclinux is ramfs,so the file just a allude file.
The fact file is stored in flash. Can I rework the fact file ? If can, how can I do?
Who can give me some advice? Thanks a lot.
you may try jffs2 on cfi flash or epcs.
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17195)
--- quote end ---
--- Quote End ---
Thanks reply.
Can you give me some hint to help me try jffs2 on cfi flash? I want to use the kernel version is 2.6.x .I can&#39;t open the web
Check the very nice guide from Jdhar,
http://via.dynalias.org/svn/uclinux/doc/trunk/epcs-ug.pdf (http://via.dynalias.org/svn/uclinux/doc/trunk/epcs-ug.pdf
who can post the pdf to me use email ?
Thanks a lot.
--- Quote Start ---
originally posted by alex824+jul 28 2006, 11:21 am--><div class='quotetop'>quote (alex824 @ jul 28 2006, 11:21 am)</div>
--- quote start ---
<!--quotebegin-hippo@Jul 27 2006, 09:57 AM
--- quote end ---
--- Quote End ---
Thanks reply.
Thanks a lot.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17209)</div>
[/b]
--- Quote End ---
updated link,
http://www.fps-tech.net/ (http://www.fps-tech.net/)
--- Quote End ---
updated link,
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17210)</div>
--- Quote End ---
Thanks I got it.
I following guide :
Or if you use cfi flash, in kernel menuconfig,
Memory Technology Devices (MTD) -->
<*> Memory Technology Device (MTD) support
[*] MTD partitioning support
<*> Direct char device access to MTD devices
<*> Caching block device access to MTD devices
RAM/ROM/Flash chip drivers -->
[*] Detect flash chips by Common Flash Interface (CFI) probe
[*] Detect non-CFI AMD/JEDEC-compatible flash chips
[*] Support for AMD/Fujitsu flash chips
(3) Retry failed commands (erase/program)
Mapping drivers for chip access -->
[*] Maps for Altera Nios Development Kit
File systems -->
Miscellaneous filesystems -->
<*> Journalling Flash File System v2 (JFFS2) support
Then rebuild the kernel, and boot nios2 uclinux.
It should display jffs2 support and detect mtd partitions.
Then I rebuild zImage and use nios2-download -g zImage to download my DVB, I did not program the zImage to dvb flash.
When nios2-download is complete , display boot information:
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 007F0000
Built 1 zonelists
Kernel command line:
PID hash table entries: 128 (order: 7, 2048 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 13824k/16384k RAM, 0k/0k ROM (1329k kernel code, 1039k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
JFFS2 version 2.2. © 2001-2003 Red Hat, Inc.
NIOS serial driver version 0.0
ttyS0 (irq = 2) is a builtin NIOS UART
ttyS1 (irq = 5) is a builtin NIOS UART
ttyS2 (irq = 6) is a builtin NIOS UART
io scheduler noop registered
io scheduler deadline registered
smc_probe: 50000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x80800300 IRQ:3 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed:00:00:00
Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00600000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
0x00600000-0x00700000 : "User configuration"
0x00700000-0x00800000 : "safe configuration"
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
NET: Registered protocol family 17
Freeing unused kernel memory: 928k freed (0x115a000 - 0x1241000)
init started: BusyBox v1.1.1-pre0 (2006.05.18-03:02+0000) multi-call binary
eth0:PHY 100BaseT
eth0:PHY Full Duplex
BusyBox v1.1.1-pre0 (2006.05.18-03:02+0000) Built-in shell (msh)
Enter &#39;help&#39; for a list of built-in commands.
Then I use mount cmd:
+++++++++++++++++++++++++++++++++++++++++++++++++++++# mount -t jffs2 /dev/mtdblock0 /mnt
Eep. No valid nodes for ino# 1#
I mount faile. Why? How can I solve it? Thanks a lot!
first, erase the flash with nios2-flash-programmer.
--- Quote Start ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17214)
--- quote end ---
--- Quote End ---
I erase the flash completd . but still mount failed.
I did not Config kernel command string "root=/dev/mtdblock0 rw rootfstype=jffs2" and not use mkfs.jffs2 to build the rootfs image.
Is it the mount fail reson?
how can I do?
Thanks a lot!
you should not set root=/dev/mtdblock0 at this time. you need to let jffs2 work first.
check if the drivers/mtd/maps/altera.c have the correct map for your board.
check the info of mtd from /sys/block .
try write and read from the mtd device, eg use "dd" .
if the mtd is erased, jffs2 will format it.
or you can make jffs2 image .
Why I did not find the /sys/block in kernel 2.6.x dir?
Where is it?
--- Quote Start ---
originally posted by alex824@Jul 29 2006, 02:45 PM
why i did not find the /sys/block  in kernel  2.6.x dir?
where is it?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17244)
--- quote end ---
--- Quote End ---
/sys is a runtime info in the nios2 linux, just like /proc.
it is not in the source tree.
Jdhar&#39;s site is updated,
what do you mean you can not save to mtd?
mtd block can be used as any other block dev.
try,
dd count=8 if=some_source_file of=/dev/mtdblock0
sync
power off, and reboot,
dd count=8 if=/dev/mtdblock0 of=out_file
but I think most problem should be at the mtd map file.
then check the content of out_file with the source_file.
Thanks hippo, I can r/w file on mtdblock0 and save it.
follow is my example:
1) crate a blank text file In ~/rootfs/etc . Rename the file to you wanted.
2)rebuild the zImage and reboot.
3)dd count=1 if=some_source_file of=/dev/mtdblock0
You have crated a jffs2 file after this step.
Then you can add c code as following demo code to your APP. So you can r/w and
save your jffs2 file. In jffs2 file you can save IP address, informaion,.........
# include <fcntl.h>
int main(void)
int ret;
int fd;
chdir("/");
char buffer[10] ={&#39;H&#39;,&#39;e&#39;,&#39;l&#39;,&#39;l&#39;,&#39;o&#39;,&#39;j&#39;,&#39;f&#39;,&#39;f&#39;,&#39;s&#39;,&#39;2&#39;};
ret = system("dd count=1 if=/dev/mtdblock0 of=test_config");
if((fd = open("test_config", O_WRONLY)) == -1)
printf("cannot open file. \n");
exit(1);
if(write(fd,buffer,10) != 10)
printf("write error");
fclose(fd);
ret = system("dd count=1 if=test_config of=/dev/mtdblock0");
return 0;
good.
the mtd block is working.
now you can try erase again and mount jffs2 on it.
--- Quote Start ---
originally posted by hippo@Jul 31 2006, 09:00 AM
good.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17286)
--- quote end ---
--- Quote End ---
I use "# mount -t jffs2 /dev/mtdblock0 /mnt"
but the erro information is:
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0x6548 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000004: 0x6a6f in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000008: 0x3273 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000000c: 0x7473 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000010: 0x6c69 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000014: 0x3a0a in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000018: 0x6e69 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000001c: 0x0a68 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000020: 0x6d65 in
stead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000024: 0x783a in
stead
Further such events for this erase block will not be printed
why?
